Jsnipes
Nov 28, 2016Aspirant
3400v3 needs internet to allow set up
Ok, so I bought one of these today and tried to set it up for internet access but the place where it is going to be finally used is not where I am at. So I did not want it to default to my internet s...
- Dec 06, 2016
"The job is not done until the paperwork is done!"
I was able to get into the set up by turning off the wireless on my computer and turning off the wireless on the router (there is a switch on the router to do this), then setting the ip address on the computer to 192.168.1.102 static (I did that to stay out of the dynamic range the router was using, it had been setting the computer's address to 192.168.1.2 and still not letting me into setup), Then both the computer and the router were restarted.
ElaineM
Nov 29, 2016NETGEAR Employee Retired
Welcome to the community, Jsnipes
The router admin page is accessible with or without Internet access.
If you're connecting it through hardwired connection, make sure that you connect the computer to one of the 4 LAN ports at the back of the router.
Once you have done that, the router should provide you an IP address of 192.168.1.x. You may see the link below for the steps on how access the admin page.
How do I log in to my NETGEAR home router?
Jsnipes
Dec 06, 2016Aspirant
- ElaineMDec 06, 2016NETGEAR Employee Retired
Are you still having problems?
