BullseyeBonez
Sep 21, 2020Aspirant
5G issue with AC1750 Model # R6350
Hello,
I have the AC 1750 dual band router (model # R6350). I pay for internet speeds up to 30 mbps. I used to get that on both bands, but for the past week, I can't get anything higher than 3 mbps on the 5G frequency. I still get full speed over wifi on the 2.4G frequency or if I plug directly into the modem or router. I've logged into the router and tried all the other channels available for 5G, but none improve the speed. Any ideas as to why I am having this problem on 5G only?
Thanks!
- BheezenGuide5g needs double the frequency. Channel 36 and up. Has anything changed in ur home? New devices tvs anything pumping out Frequency? Changing the channel can sometimes help but I have seen everything from Google Nests to Doorbells to Surveillance affect ur connection.
Check into WiFi analyzer or similar WiFi channel sniffer... if techie u can see what’s going on.- BullseyeBonezAspirant
Thanks, Bheezen . Nothing has changed tech-wise in our house. I downloaded a wifi analyzer app, but am not super tech-smart. It seemed to imply the best channel for my 5G setting was where I have it. I bought a desktop that came with a dual band USB wifi device. It's now the only computer or device not getting good speed on 5G wifi. I tried another laptop on 5G and it was fine. So, it seems like the problem is either in my desktop or the USB device? Any ideas on how I can figure that out?
Thanks!
- BheezenGuideWhen u say USB WiFi device, do u know what it is? I am guessing but it may be a dead zone, usb WiFi device issue like a driver, interference from that spot to the router.
Instead of drilling u with questions, this is what I would do.
1) pull up ur device connection settings and confirm ur network band, channel connected, and protocol (802.11X) and Link speed if available. Assuming all good...
2) reboot and run a speed test on it to show what ur pulling for download speed. If ur speed is bad...
2) pull in another device at that exact location and run a speed test on that device connected to 5g. (This would help in diagnosing if ur WiFi device or dead zone).
Shoot me ur WiFi adaptor make and model and that would help troubleshoot too
