Minar
Jul 20, 2023Aspirant
5G not working on my R6120
After I factory reset the router 5G didn't work again . Can anyone help me please.. .My router is Netgear R6120.
Minar
Jul 24, 2023Aspirant
There is no dedicated light for 5g output indication. I have tried restarting ,factory reset, press and hold reset button etc. but didn't work..
michaelkenward
Jul 25, 2023Guru - Experienced User
How did you diagnose that there is no 5 GHz broadcasting?
By the way, did you realise that the R6120 has very basic specifications? It may support 5 GHz wifi, but there isn't much point in doing so.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
