lemick
Nov 20, 2023Aspirant
5G on N300WNR2000v4
N300 WNR2000 v4 The box says "Simultaneous Dual Band--runs 2.4 and 5GHz bands concurrently" but it connects only at 2.4. How do I get it to connect at 5?
lemick
Nov 28, 2023Aspirant
Well, I suspect you are correct about its age and limits, but the unit labeling matches the box exactly--and the same box says, on one end panel, N300 Wireless Router (WNR2000v4) and on the other end panel, "Simultaneous Dual Band--runs 2.4 and 5GHz bands concurrently."
The router is connected to Spectrum's internet modem and to my Windows 10 PC.
Maybe I am mis-understanding "runs 24. and 5GHz band concurrently"???
michaelkenward
Nov 28, 2023Guru - Experienced User
Over the years Spectrum will have provided many different modems to customers. That may include modem/routers.The important detail is the make and model number.
You are right. The data sheet says "Simultaneous Dual Band—runs 2.4 and 5GHz bands concurrently". But the next bit says "IEEE 802.11 b/g/n 2.4 GHz". No mention of 5 GHz.
The manual doesn't even refer to 5 GHz.
Another spanner in the works is that the LAN connection is just 100BASE-Tx, so even if the router could handle 5 GHz wifi, you would not get that out of the internet.
I think not. It is just another case of bad proofreading of the documentation.
You might find this entertaining:
Solved: N300 can't find my 5G network - NETGEAR Communities
And that device is younger than yours.
