knjb's avatar
knjb
5GHz wi-fi only works with no security
I recently purchased a used R8900 Nighthawk x10 on eBay, and I've tried just about everything I can think of to get the 5GHz wifi working. But, it will only connect successfully if I turn off the WPA...
  • knjb's avatar
    knjb
    Dec 09, 2020
    To update the situation, I found all the information about uploading the firmware via TFTP while it's in the recovery state. I was able to successfully update the firmware that way, but it didn't resolve the issue.
    So, at this point, I think it's safe to say that the hardware is just defective, and I'll try to get a refund. Thanks to everyone for the replies!
