knjb
Dec 08, 2020Aspirant
5GHz wi-fi only works with no security
I recently purchased a used R8900 Nighthawk x10 on eBay, and I've tried just about everything I can think of to get the 5GHz wifi working. But, it will only connect successfully if I turn off the WPA...
- Dec 09, 2020
To update the situation, I found all the information about uploading the firmware via TFTP while it's in the recovery state. I was able to successfully update the firmware that way, but it didn't resolve the issue.
So, at this point, I think it's safe to say that the hardware is just defective, and I'll try to get a refund. Thanks to everyone for the replies!
knjb
Dec 09, 2020Aspirant
Thanks for the reply! Yes, I've tried factory reseting the router many times, and I gave the recovery reset 3 tries as well. Each time with the recover reset, the power LED light just flashes endlessly until I turn the router off and back on.
I can see in the manual that:
If the Power LED blinks slowly and continuously, the router firmware is corrupted. This can happen if a firmware upgrade is interrupted, or if the router detects a problem with the firmware. If the error persists, it is likely that a hardware problem exists.
I've tried reinstalling the firmware and switching firmwares after turning it back off and on, but does the blinking power LED mean that it's in recovery mode and that I should try installing a firmware somehow while it's in this state?
The manual just says to contact support for recovery instructions.
knjb
- michaelkenwardDec 09, 2020Guru - Experienced User
Sounds like a reasonable conclusion.
