WMetzner's avatar
WMetzner
6250 and Chromecast
Chromecast ist only working on the slow side of my router, not the 5g portion. If I read the chromecast instructions correctly, then I should put the route into "AP isolation : off". The manual refers...
  • WMetzner's avatar
    WMetzner
    Nov 03, 2015
    Ha, I bet that is it; I have had that Chromecast for close to two years. So it must be a first generation.
    Thanks "TheEther", for clarifying this.
    Much appreciated!
    Wolf
