curly53
Jul 06, 2022Aspirant
6400v2 stopped broadcasting 5G and Nighthawk times out so i cant get in to check
Router is less then 2 years old. tried Nighthawk on 2 diff phones and apk on fire tablet but all time out after a few seconds. even old genie times out. how can i check things out. if i hard reset an...
curly53
Jul 07, 2022Aspirant
Genie is the older app from Netgear. All my lights are on, internet is fine which is how im able to be on here. All my devices connect to 2G just fine. Its just the 5G that has disappeared. Wifi search on PC and phones only show my 2G network.
michaelkenward
Jul 07, 2022Guru - Experienced User
Yes. But which one? Mobile for Android/iOS or desktop for Windows/MacOS? Netgear likes to make these things difficult.
The firmware update that allowed the Nighthawk app to work on the R6400v2 will have killed the genie.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
If the Nighthawk app works on your phone the genie won't. You can't get both to work.
5 GHz has a shorter range than 2.4 GHz. Maybe it got lost?
As you have a PC have you tried using a wired LAN access to get at the browser graphical user interface (GUI)?
- plemansJul 07, 2022Guru - Experienced User
What IP address are you trying to use to access the router?
What device are you using? If its a mac/ios device, make sure icloud relay and private mac/ip address are disabled.
