zm23
Feb 17, 2021Aspirant
A6100 keeps disconnecting and acting up, tried practically everything.
I bought my A6100 from BestBuy about a week and a half/ 2 weeks ago. For the first week or so, it worked completely fine, exactly how it should. One afternoon, it completely lost access to the interne...
Feb 18, 2021Guru - Experienced User
try this fix.
https://www.youtube.com/watch?v=ELhMSdv3-Xs
- zm23Feb 18, 2021AspirantI got stopped almost immediately. I went to search for RunSW, but I cant find it at all. I went through the R’s one by one, and found nothing. Thanks for the suggestion though
- plemansFeb 18, 2021Guru - Experienced User
Try uninstalling the driver and utility.
Then install the standalone driver.
