Duetto
Jun 12, 2022Aspirant
a6150 connection issue
my a6150 dual wifi adapter is not working. when inserted it is blinking blue slowly but sees no 5G sites. my laptop is running win10. i have uninstalled/re-installed the drivers. i found one olde...
- Jun 14, 2022
Duetto
Jun 14, 2022Aspirant
hi,
thanks for the reply. i now have it running. i reinstalled and then went into device manager/network adapter/netgear a6150 and changed the mode setting from auto to b/g/n/ac. i think the change forced it to look at ac or 5G.
all i know is it's working. you can mark as solved.
duetto
michaelkenward
Jun 14, 2022Guru - Experienced User
