MKWhite1956
Nov 28, 2023Aspirant
AC 1200 Netgear47 router, model #R6120
I would like to know if this router is a WI FI 6 as I am looking to purchase a firestick 4K
- Nov 28, 2023
No, WiFi 4/5. You'll need something from NG that has RAX in the model for WiFi 6 support.
Nov 28, 2023Guru - Experienced User
- MKWhite1956Nov 28, 2023Aspirant
Thank You
- plemansNov 28, 2023Guru - Experienced User
Are you looking for wifi 6 (2.4ghz/5gh) or something with 6ghz?
6ghz would be a wireless 6E device.
- michaelkenwardNov 28, 2023Guru - Experienced User
Overkill. If the idea is to use a Firestick:
MKWhite1956 should read the small print.
