MKWhite1956
Nov 28, 2023Aspirant
AC 1200 Netgear47 router, model #R6120
I would like to know if this router is a WI FI 6 as I am looking to purchase a firestick 4K
- Nov 28, 2023
No, WiFi 4/5. You'll need something from NG that has RAX in the model for WiFi 6 support.
Nov 28, 2023Guru - Experienced User
MKWhite1956
Thank You
- plemansNov 28, 2023Guru - Experienced User
Are you looking for wifi 6 (2.4ghz/5gh) or something with 6ghz?
6ghz would be a wireless 6E device.
- michaelkenwardNov 28, 2023Guru - Experienced User
Overkill. If the idea is to use a Firestick:
MKWhite1956 should read the small print.
michaelkenward some versions have 6ghz.
https://developer.amazon.com/docs/fire-tv/device-specifications-fire-tv-streaming-media-player.html
https://dongknows.com/fire-tv-stick-4k-max-2nd-gen-2023-review/
