mk654
Apr 20, 2022Follower
AC 1200 R6120 not working anymore after update
I had new update on my wifi router. I started it and suddenly my phone said that i can’t do it. And now I can’t use my wifi. There is flashing green light on power. What I have to do?
Apr 20, 2022Guru - Experienced User
Sounds like you might have corrupted the firmware. we always recommend on here to update over a hardwired connection for best results.
Did you try factory resetting? Push and hold reset for 7-15 seconds while powered on.
If that doesn't help, you can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
