bote110
Apr 23, 2018Tutor
AC-1200 R6220 router issues
bought new in 2014 and now I loose conection on my notepad ,tvo an android box , all will switch over to my router from my AC-1200 . I updated the new frimware and same thing. I reboot the router and...
- Apr 25, 2018
Thanks for the reply , I taught this might had been the problem from the beginning since my AC1200 is 4 years old.
michaelkenward
Apr 25, 2018Guru - Experienced User
bote110 wrote:
....quick question is the AC-1200 supost to be left on 24/7 ? or shut off when not in used? I notice it gets warm .
Most people leave these devices on all the time. After all, they usually want constant access to the internet without having to turn something on and off.
All electronic devices generate some heat.
bote110
Apr 25, 2018Tutor
