reachchandra's avatar
reachchandra
Follower
Apr 12, 2017
AC-1200 Smart WiFi Router with External Antennas stops working again and again
Hi  , I have brought  a new router  . I have lease line connection in my office .  I have configured the router and it works well for some time , then it disconnects  from the internet  .  I tried with other netgear router, there is no disconnection  . whenever this happens i rebooted the router  and it start working again but after 10 minute or so it disconnect's . pls advice is there any problem with the router or i am missing some point  .
After configuration  , one need reboot the router again and again.
Prakash Chandra
976 330 3421
India
  • Hi reachchandra,
    Please try resetting the router to factory defaults. If the issue persists, you can try re-flashing the firmware then reset and reconfigure it again.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi reachchandra,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi reachchandra,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
