Jayfisch
Jul 29, 2022Aspirant
AC 1750 smart router connection issue
All lights on the AC 1750 are on and white. All devices in home show Wi-Fi signal is there and it’s connected. But can’t use Internet from any device; Says to check Internet connectivity. I have no id...
Jayfisch
Aug 03, 2022Aspirant
Thank you for your response. Here is some better information. The unit is an R 6400 smart router. My mom has been using it for at least a couple of the years with no problem Until now. All the lights are white and the devices in the room including two iPhones, TV and Nook detect the Wi-Fi Single but none can use it. Messages say check Internet connection. I’ve tried resetting and rebooting both router and modem With no effect.
- michaelkenwardAug 03, 2022Guru - Experienced User
Jayfisch wrote:
I’ve tried resetting and rebooting both router and modem With no effect.What was that modem?
If you mean that you have used the "reset" button on the back, you'll need so set it up from scratch. The Quick Start guide could help there.
- JayfischAug 03, 2022Aspirant
The modem is a Hitron Tech. EN2251. All 3 modem lights are lit blue as well as all router lights lit white. I have tried pushing/holding the reset button on back of router for at least 30 seconds and I've unplugged both units for at least 30 seconds.
As I mentioned, all devices "see" the wifi signal but none can use it. Seems like an odd problem to me. I hope you can help.
Thanks!
Jay
- KitsapAug 03, 2022Master
Jayfisch wrote:The modem is a Hitron Tech. EN2251. All 3 modem lights are lit blue as well as all router lights lit white. I have tried pushing/holding the reset button on back of router for at least 30 seconds and I've unplugged both units for at least 30 seconds.
Thanks!
Jay
For the devices in the room, see if there is an option to forget the connection and establish it fresh with the SSID and password. As a test you might try a new and completely different SSID and establish the connection to one of your devices.
There is a chance the devices do not support or cannot handle the Wi-Fi security options (WPA, WPA2, etc.) or need "none" selected. You may have to test and rely on trial and error.
