msanangelo
Mar 03, 2022Follower
AC 1900 wifi range extenser EX6400 v3
Purchased Sept 2021 Through process of elimination, the intermintent dropping of internet connection appears to be with the Range extender model listed above. Its not the cable signal and its...
Mar 03, 2022Guru - Experienced User
What router are you connecting it to?
what firmware is on the extender?
How far from the router is the extender?
Whats in between the extender and the router (walls, what the walls are made of, etc)
What speeds do you pay for (upstream and downstream)?
If you test your speed on the extender, what speeds are you getting for: 2.4gh? 5ghz?
Did you set it up using wps or using the installation assistant?
