nanonpawt
Feb 17, 2022Follower
AC Adapter for Netgear Router
Will my AC adapter, which is rated at 10V and 1.2A, work with my Netgear WNDR3800 router, which is rated at 12 V, 2.5A? Is there a general rule of thumb for this, for example: "if both V and A are lo...
Feb 17, 2022Guru - Experienced User
It might run for a bit with lower amperage but it won't be stable.
You can run with a higher amperage power supply but a lower will cause instabilities and issues.
- wcalifasFeb 17, 2022Prodigy
if it works your router will be running slower, maybe even wifi disconnects from it being under the necessary voltage.
