nanonpawt
Feb 17, 2022Follower
AC Adapter for Netgear Router
Will my AC adapter, which is rated at 10V and 1.2A, work with my Netgear WNDR3800 router, which is rated at 12 V, 2.5A? Is there a general rule of thumb for this, for example: "if both V and A are lo...
michaelkenward
Feb 18, 2022Guru - Experienced User
As everyone else says, bad idea.
I chip in only to suggest that you look around for something else in the house that might have the right specifications.
12 V, 2.5A is a pretty widespread specification for electronic kit. For example, I have seen it on powered USB and other PC peripherals.
