PinWiz70
Aug 07, 2020Aspirant
AC1000 R6080 LAN 50% speed issue
Hey all. I've scoured the threads and apologize if I'm asking the same question someone else did. Specs: AC1000 R6080 V1.0.0.44 Setup: Arris (Spectrum) cable modem to R6080 router. One desk...
- Aug 08, 2020I'm sorry. Perhaps I should have made myself clearer. Your router is limited to a theoretical maximum of 100 Mbps. It cannot talk to anything faster than that. It has no chance of achieving the speed you are paying for. And even that 100 Mbps is debatable. It is, as I said, theoretical. Throw in the processing overhead and the need to accommodate other things on your network and it won't do 100 Mbps either. The speed loss you report could be down to various factors. The bottom line is that it is not up to the job.
michaelkenward
Aug 08, 2020Guru - Experienced User
PinWiz70 wrote:
I have 100+mbps service. If I connect my computer direct to the modem, fast.com shows 120mbps.
Your Internet is faster than your router.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. Newer devices support 1000BASE-TX.
The surprise is that Netgear was still selling stuff that slow in 2017.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
PinWiz70
Aug 08, 2020Aspirant
michaelkenward My internet is faster than my router. Yes I know that. I made mention of that. I said I was fine with that. That's not the issue.
Is there anyone that can explain why a R6080 router, factory reset with the lastest firmware, one computer wired to it, zero wifi traffic throttles speed 50%?
Computer A ----- Cable modem ------ 120mpbs
Computer A ----- R6080 router ----- Cable modem ----- 55mbps
- michaelkenwardAug 08, 2020Guru - Experienced UserI'm sorry. Perhaps I should have made myself clearer. Your router is limited to a theoretical maximum of 100 Mbps. It cannot talk to anything faster than that. It has no chance of achieving the speed you are paying for. And even that 100 Mbps is debatable. It is, as I said, theoretical. Throw in the processing overhead and the need to accommodate other things on your network and it won't do 100 Mbps either. The speed loss you report could be down to various factors. The bottom line is that it is not up to the job.
- PinWiz70Aug 08, 2020Aspirant
michaelkenward wrote:
I'm sorry. Perhaps I should have made myself clearer. Your router is limited to a theoretical maximum of 100 Mbps. It cannot talk to anything faster than that. It has no chance of achieving the speed you are paying for. And even that 100 Mbps is debatable. It is, as I said, theoretical. Throw in the processing overhead and the need to accommodate other things on your network and it won't do 100 Mbps either. The speed loss you report could be down to various factors. The bottom line is that it is not up to the job.Ah alright that makes sense to me. Thanks for the clarification. I'm dumping the R6080 in favor of a TP-Link Archer A6. Gigabit LAN ports. Forget this 10BASE-T or 100BASE-TX stuff.
Thanks again
- PinWiz70Aug 16, 2020Aspirant
Update: I installed a gigabit LAN wireless router and all problems were solved. Internet speeds doubled from 55mbps to 100+mbps
