PinWiz70's avatar
PinWiz70
AC1000 R6080 LAN 50% speed issue
Hey all. I've scoured the threads and apologize if I'm asking the same question someone else did. Specs: AC1000 R6080 V1.0.0.44 Setup: Arris (Spectrum) cable modem to R6080 router. One desk...
  • michaelkenward's avatar
    michaelkenward
    Aug 08, 2020
    I'm sorry. Perhaps I should have made myself clearer. Your router is limited to a theoretical maximum of 100 Mbps. It cannot talk to anything faster than that. It has no chance of achieving the speed you are paying for. And even that 100 Mbps is debatable. It is, as I said, theoretical. Throw in the processing overhead and the need to accommodate other things on your network and it won't do 100 Mbps either. The speed loss you report could be down to various factors. The bottom line is that it is not up to the job.
