Sarahk4t
Apr 26, 2022Aspirant
AC1000 R6080 won’t connect to IP Address
Okay so my router all of a sudden doesn’t recognize my IP address. The internet light is amber. I’ve tried all sorts of resets. How can I figure this out?!
Apr 27, 2022Guru - Experienced User
What modem/gateway do you have it connected to?
what firmware is on the router?
do wired devices work?
Sarahk4t
Apr 27, 2022Aspirant
Not sure about modem! Think it’s the new fiber setup though! The city installed it! Just updated the firmware V1.0.0.46. Don’t have any wired devices that I can use to check!
- plemansApr 27, 2022Guru - Experienced User
Check the modem/gateway/ont. You can get nat issues if the gateway has its own integrated router (which many do)
