RenoSharks01
Mar 04, 2021Aspirant
AC1000 router not working with HP printer
Hello, I just upgraded my modem and router to Netgear. It took my half the day yestrday to get the wi-fi going so I could use internet on laptop, Kindle, and smart tv (would be nice if start-up g...
antinode
Mar 04, 2021Guru
> AC1000 router [...]
"AC1000" is a speed, not a model number. Look for "Model" on the
product label.
> Model: R6080|AC1000 Dual Band WiFi Router
"R6080" is a model number. Firmware version? Connected to what?
> I just upgraded my modem and router to Netgear. [...]
What did you have before? Now?
> [...] It took my half the day yestrday to get the wi-fi going [...]
What were you doing for all that time? Setting the SSIDs and
passphrases on the R6080 to match those of your (unspecified) old router
should occupy a few minutes. And then your old devices should just
work.
Did you end up having to reconfigure your other (unspecified)
wireless devices?
> [...] My printer won't work, [...]
And did you _not_ reconfigure your printer?
"won't work" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> Any suggestions.
If the printer is your only non-working gizmo, then I'd visit hp.com,
get the set-up instructions for your printer, and follow them.
