MikePeterson
Oct 05, 2023Aspirant
Ac1000 Router
When I try top connect the router, I'm told top enter the security code, I enter the WPA2 and it tells me that's incorrect and I 'm still not connected.
microchip8
Oct 05, 2023Master
Connect to what?
Enter security code where?
Which router model? AC1000 is a speed, not model number.
- MikePetersonOct 05, 2023Aspirant
- michaelkenwardOct 12, 2023Guru - Experienced User
microchip8 wrote:
Which router model? AC1000 is a speed, not model number.The only AC1000 I can find in the system is the R6080, probably the bottom of the line for Netgear routers. I mean, 100 MBps LAN and WAN in 2017? Not something to use if the Internet is faster than 100 MBps.
A good place to start looking for help is the manual.
Visit the support pages:
Support | NETGEAR
Feed in the model number and check the documentation for that hardware.
