Techmichelle
Jul 12, 2021Aspirant
AC1200 / R6120 2.4 wireless NOT working
Hi Looking for some ideas. Unboxed this router and reset the 2.4 and 5 SSID and password. I was unable to connect the 2.4. I did a factory reset. The 5 connects, the 2.4 does NOT. Suggestions...
Techmichelle
Thanks for the idea. Yes the smart phone can connect to the 2.4.
Windows 10 Laptop gives a Can't Connect error.
plemans wrote:What error do you get?
do all devices have issues or just one?
any special characters in the ssid/password? (try removing them if you do)
Jul 14, 2021Guru - Experienced User
Is it only that device?
