Draigmarchog's avatar
Draigmarchog
Follower
Dec 04, 2021
AC1200 can’t connect
I moved into a new apartment where the router was already here. But I’m not finding the WiFi name on my phone when I go to try to connect. So I tried setting up a new account for it through the app but the QR code is gone, I don’t have access to the modem, so I’m not sure what to do.
Anyone have advice? Thanks in advanced!
  • plemans's avatar
    What router model is it?
    Have you checked with the apartment manager?
  • michaelkenward's avatar
    michaelkenward
    Your footer says  MBR1200. That's a Mobile Broadband Wireless Router. Not something that you are likely to find in an apartment.
    It is also ancient (2010) and doesn't seem to feature in the user community.
    So what are we talking about here?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That page will also have any software, firmware and drivers for your device, if they exist.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
