klimspeed
Jan 07, 2026Aspirant
AC1200 cuts 30Mbps off bridge speed
I set up an AC1200 as an access point wired by 4 pair Ethernet cable to the slave of a Ueevii bridge (from main router in office to AP on house). Testing speeds on a Android in the house I get 90Mbp...
klimspeed
OK. I found a Ueevii bridge system CPE5824WR
https://www.amazon.com/UeeVii-Bridge-Router-Kit-WiFi-dp-B0DTJRX1SF/dp/B0DTJRX1SF/ref=dp_ob_title_ce
with ports that support 1000Mbps.
My TP-Link C8 connected to Starlink modem is putting out 190Mbps. But Starlink plans commonly deliver only 100-300 Mbps, so I guess the TP-Link is doing its best. A beefier bridge should at least get me over 100Mbps in the house.
Jan 07, 2026Guru - Experienced User
Good Luck.
