AnniePannie
Feb 16, 2021Aspirant
AC1200 Dual Band WiFi range Extender
The extender network does not accept the router password
AnniePannie
yes it's EX6110
No idea what firmware (don't know what that is)!
Router: provided by Utility Warehouse - on the back it says technicolor DWA0120
Tried both for set up
Do not have a Netgear router.
I tried moving the extender back closer to the router and it connected for a mili second and then disconnected........?
Feb 16, 2021Guru - Experienced User
Try factory resetting the EX6110 and reinstalling it 1 more using the installation assistant.
Push and hold reset for 7-15 seconds while the extender is powered on.
then use the installation assistant.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
- AnniePannieFeb 16, 2021Aspirant
Thanks, but can't - the reset button appears to be missing!! (and I can't find the receipt to return it)!!! Argh..............
- plemansFeb 16, 2021Guru - Experienced User
Its on the left side of the device. The manual goes over it.
