jhsmith777
May 05, 2022Follower
AC1200 Dual Band WIFI Router
I had to turn off my Netgear 94 because of electrical storm. Trying to reset it. One of the lights are red and the other 3 are green. What is wrong and do I have wifi? What do I do to get the red...
michaelkenward
May 06, 2022Guru - Experienced User
What "reset" are you trying?
Which light is red? Power? Internet? Something else?
Which router do you own AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
After you turned things back on, did you follow the right order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Begin with the Quick Start/Installation Guide.
