jhsmith777
May 05, 2022Follower
AC1200 Dual Band WIFI Router
I had to turn off my Netgear 94 because of electrical storm. Trying to reset it. One of the lights are red and the other 3 are green. What is wrong and do I have wifi? What do I do to get the red...
May 06, 2022Guru - Experienced User
If you follow to the support site michaelkenward pointed out, you'll be able to find out what each led is and what they mean.
Details of which ones are lit up and specific help us to help you.
Storms are great at wrecking electronics.
If you're able to log into it, you might retry reloading the firmware on it in case the storm corrupted something in the firmware.
