Marcella555
May 27, 2022Follower
AC1200 Forgotten Password
michaelkenward
May 28, 2022Guru - Experienced User
Search - NETGEAR Communities – Forgotten Password
AC1200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- plemansMay 28, 2022Guru - Experienced User
wonder if this got split off for some reason and why?
maybe from this post? https://community.netgear.com/t5/Nighthawk-WiFi-Routers/AC1200-Forgotten-Password/m-p/2227692
