Greger24688
Feb 19, 2022Follower
AC1200 Limits Ethernet Speeds
 So I bought this router a while ago to get better coverage around my flat (walls are shading signal like crazy for whatever reason). And I was lazy for a while to fix the issue of the slow ports and ...
- Feb 19, 2022The R6120 isn't a gigabit router. Its only fast ethernet. Meaning its wan/lan ports are only 100mbps rated. So that'll be the fastest speed you can get from it. If you want faster speeds, you'd need to upgrade to a gigabit device.
Feb 19, 2022Guru - Experienced User
