Bj63
Nov 17, 2022Tutor
Ac1200 Model R6120 Internet light staying amber
I have AC1200 R610 wifi router. The internet LED light is just staying amber the entire time. I still have internet but it's been rather stuttery ever since getting a firmware update from NETGEAR. Do...
Nov 17, 2022Guru - Experienced User
From looking at the manual, the internet light is either off or green. Are you sure you're looking at the correct one?
LED Description
Power LED
Solid green. The power is on, and the router is ready.
Blinking green. A firmware update is in progress.
Off. Power is not supplied to the router.
WiFi LED
Solid green. The wireless radio is operating.
Off. The wireless radio is off.
Internet LED
Solid green. The Internet connection is ready.
Off. No Ethernet cable is connected between the router and the modem.
Ethernet ports 1–4
LED
Solid green. A powered-on device is connected to the Ethernet port.
Off. No device is connected to this Ethernet port.
- Bj63Nov 17, 2022Tutor
I found that in the manual as well, which is why I am confused. I am quite positive I am looking at the correct light. All the others on the wifi router are green, the one that shows I have internet is amber/orange. But I still have internet, which is confusing.
