Bj63
Nov 17, 2022Tutor
Ac1200 Model R6120 Internet light staying amber
I have AC1200 R610 wifi router. The internet LED light is just staying amber the entire time. I still have internet but it's been rather stuttery ever since getting a firmware update from NETGEAR. Do...
michaelkenward
Nov 19, 2022Guru - Experienced User
Bj63 wrote:
I have AC1200 R610 wifi router. The internet LED light is just staying amber the entire time. I still have internet but it's been rather stuttery ever since getting a firmware update from NETGEAR. Does the LED light not being green all the time matter?
How fast is your Internet service? If you ever get an Internet service that is faster than 100 Mbps (probably faster the 95 Mbps in reality) you won't see the benefit.
The R6100 is one of Netgear's bottom of the range router. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware.
Your modem has an Ethernet connection that runs at 1000 Mbps. Connecting it to a 100 Mbps router throws away a lot of speed and probably hobbles your wifi in the process.
- Bj63Nov 25, 2022Tutor
According to my service provider I have 300Mbps. If you're saying my router/modem is lack luster..I would like to know what option would be best as I am only using what was provided.
- michaelkenwardNov 25, 2022Guru - Experienced User
Your ISP is delivering 300 Mbps. You will never get anything faster than 100 Mbps out of the R6100 router. Your CM600 modem, on the other hand, can handle up to 1000 Mbps.
The specifications say:
LAN and WAN 10BASE-T or 100BASE-Tx, RJ-45
Just about any other router you buy will have at least 1000BASE-Tx. Your modem can deliver that.
Be prepared for a massive increase in the speed of your Internet service with a new router.
So new wifi router will increase my speed? Just to clarify. I'm quite tech illiterate. If that is the case, thanks very much!
