Bj63
Nov 17, 2022Tutor
Ac1200 Model R6120 Internet light staying amber
I have AC1200 R610 wifi router. The internet LED light is just staying amber the entire time. I still have internet but it's been rather stuttery ever since getting a firmware update from NETGEAR. Do...
Nov 25, 2022Guru - Experienced User
Bj63 wrote:
So new wifi router will increase my speed? Just to clarify. I'm quite tech illiterate. If that is the case, thanks very much!
Contingent on the fact that you'd need to make sure to pickup one that's gigabit capable.
I'd hate to see you buy another base model device that didn't have gigabit and be stuck at the same speed.
michaelkenward
Excellent point.
But it would be very hard to buy another Netgear router that wasn't at least Gigabit LAN. The R6XXXX range is among the few, and only the lesser ones there. The R6080, R6100 and R6120 are part of a tiny handful.
The shocker is that Net5gear even sold these things as recently as 2017.
Just look on the labels, and do not be fooled by references to "fast ethernet". That really means "slow ethernet". It is also a good way of weeding out things not to buy. If it says "fast ethernet" leave it on the shelf.
- TXShooterApr 29, 2023Aspirant
I, too, have the AC1200 WiFi Router Model R6120. I know not what the modem model is, but it's from Viasat (so it's probably junk). I bought the R6120 through Amazon because of its high ratings and low price. I guess I got suckered, but I don't know where to get the "BEST" information. The Internet LED (third from left) is also solid amber. All others are green. WTF?
- michaelkenwardApr 29, 2023Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
