naweenio
Jul 13, 2022Follower
AC1200 not able to reset and can't remember security questions
I cannot reset to factory using the reset button. Does anyone know of another way to do it? I need to check settings.
Jul 14, 2022Guru - Experienced User
Are you pushing and holding reset for up to 30 seconds while powered on?
what happens when you do this?
