Previzionn
Jan 07, 2018Tutor
AC1200 R6120 Router Slowing Down Internet
I just bought an Arris SURFboard 32x8 cable modem (SB6190) and a Netgear AC1200 (R6120) router. The firmware that is on my router is V1.0.0.36. When I am plugged in directly to the modem, I am gettin...
- Jan 08, 2018
I figured out what the problem is. I am just an idiot that did not read the box carefully. The box says it supports 300 + 900 Mbps on the front, but on the side it says that the LAN throuput is only 100 Mbps.
michaelkenward
Jan 08, 2018Guru - Experienced User
Things that people have tried to fix the "router is throttling my modem" issue with various devices:
- Ensure that the cable from the router to the modem is up to the job
- Check that you have the latest firmware (and "factory reset" the device)
- Check that you have the right internet settings for your ISP (especially MTU)
- Turn off QoS
- Turn off the Traffic Meter
Netgear also advises that you should turn off QoS if you are on Gigabit Internet. You don't need it.
- PrevizionnJan 08, 2018Tutor
I tried everything you suggested except for turning off QoS and the Traffic Meter and have not had any success at improving the speeds. When I Google how to turn of QoS and the Traffic Meter, it tells me sign in at www.routerlogin.net. Then, I should go to Advanced and I should be able to find QoS under Setup and Traffic Meter under Advanced Setup; however, these do not exist for me. I cannot find them anywhere else. Do you have any suggestions?
