Previzionn's avatar
Jan 07, 2018
AC1200 R6120 Router Slowing Down Internet
I just bought an Arris SURFboard 32x8 cable modem (SB6190) and a Netgear AC1200 (R6120) router. The firmware that is on my router is V1.0.0.36. When I am plugged in directly to the modem, I am gettin...
  • Previzionn's avatar
    Jan 08, 2018
    I figured out what the problem is. I am just an idiot that did not read the box carefully. The box says it supports 300 + 900 Mbps on the front, but on the side it says that the LAN throuput is only 100 Mbps.
