KuanYinTi's avatar
KuanYinTi
Follower
Jul 14, 2017
AC1200 R6120 ROUTER
I just bought Netgear AC1200 R6120 Router and have a question. Can I have 2 different SSID names and 2 separate security passphrases or do I have to use only 1 in both the 2.4 Ghz and the 5 Ghz in th...
  • DexterJB's avatar
    Jul 17, 2017
    Hi KuanYinTi,
    Yes, you can set different SSID's and WiFi passwords for the 2.4GHz and 5GHz bands. Yes, you can also change it back to the defaults if you prefer.
    Dexter
    Community Team
