danstar10
May 17, 2022Aspirant
AC1200 R6120 throttling speeds - need to upgrade?
Hi all, I just installed a Netgear AC1200 R6120 and I am finding my up and download and upload speeds seem to be throttled, which is not a problem I was having with my pretty old TP link DIR-826L. T...
May 17, 2022Guru - Experienced User
Wireless no, wired should be near 100Mpbs. Nothing over.
This router is of older generation and maybe time to find something newer. Give you some head room and future proofing some as well.
danstar10
Hmm seems like wired is not doing what it should then. But as you say maybe I should go for a higher spec router anyhow for long term.
If a router is listed as a 'gigabit' router, does that mean it can support speeds up to 1Gbps if the supplied internet is that fast? And would that work both wired and wireless?
For example:
Cheers
Dan
- FURRYe38May 17, 2022Guru - Experienced User
No. "speeds up to 1.9 Gbps (1900 Mbps - 600 on 2.4 Ghz and 1300 on 5 Ghz" These are combined speeds for marketing. Again, would not see anything near 900Mpbs on 5Ghz AC. Close. Also be aware that there are limiations on wifi devcies themselves. 2x2 antenna configurations are most common on phones and pads. These tend to max out at around 500Mpbs on 5Ghz AC at 80Mhz channel width. 4x4 antenna configurations have the ability to use and see near 900Mpbs and over. Helps if a routers supports 160Mhz channel width as well. Not all do. Also WAN and LAN port speed is important as well. Most common now days is 1000Mbps. Newer stuff is seeing 2.5Gb WAN and LAN and 10Gb on the WAN side.
- michaelkenwardMay 18, 2022Guru - Experienced User
Yes and no. It depends on what the label refers to. Wifi or Ethernet.
Next to nothing will deliver gigabit wifi. You need the latest and greatest wifi technology at both ends of the connection. (Do not confuse claimed connection speeds with traffic throughput.) Few wifi clients can get anywhere near that.
Devices that claim to have 1000 Mbps (or Gigabit) Ethernet, sometimes labelled as "1000M BASE-T", should get near to that speed with wired connections. It doesn't help that device makers sometimes use the label as "Fast Ethernet" ports that are 100 Mbps.
The important bit on Internet speeds is the link between the modem and the router. If that is stuck at 100 Mbps, like the R6120, you will never get an Internet connection above 100 Mbps. In reality probably a bit less.
- danstar10May 18, 2022Aspirant
ok thanks for the info guys, I appreciate it
