airasel
Aug 19, 2019Aspirant
AC1200 R6220 Gigabit Router
Hello, Netgear team i need a troubleshoot. My Router is R6220 with latest version of firmware V1.1.0.86 installed, and it's connected to optical fibre modem C-DATA/ONU. My service provider is Ra...
DexterJB
Aug 21, 2019NETGEAR Moderator
Hi airasel, may we know how are you testing the speed separately for the YouTube and for regular browsing?
Dexter
- airaselAug 22, 2019Aspirant
Hi DexterJB thanks for the reply, i can't test the speed separately, PC connect with Router then download from YouTube with IDM i get speed in seconds 2.537mbps to 2.570mbps thats mean line speed nearly 20Mbps, several times cancel or re-download attempt i get 6.276mbps to 6.396mbps nearly 48 to 50Mbps speed.
Without Router i get decent speed from YouTube with IDM 5 to 6Mbps in seconds nearly 50Mbps of speed when my provider check, after this test they told me my Router's getting old should bought a newer one.
