xcskier's avatar
xcskier
AC1200 R6220 wallmount
This is one of the least technical questions on this board.  I'd like to mount my 6220 router on the wall.  The bottom face of the router has two -o- type holes, as if intended for two mounting screw...
  • DexterJB's avatar
    DexterJB
    Feb 12, 2018
    Hi @xcskier,
    There is actually a gap between the router's back and the plate which is enough for a flat screw head to slide in.
    R6220_Mount
    Dexter
    Community Team
