xcskier
Jan 31, 2018Aspirant
AC1200 R6220 wallmount
This is one of the least technical questions on this board. I'd like to mount my 6220 router on the wall. The bottom face of the router has two -o- type holes, as if intended for two mounting screw...
DexterJB
Feb 11, 2018NETGEAR Moderator
Hi xcskier,
Thank you for providing the photo.
The plates are there as intended and serve as some sort of stopper for the mounting screw so that it will not make contact with the router's internals. That also means that the mounting screw head should not really penetrate deeper than the plates. All you have to do is align the screw head at the center of mounting slot and slide the router up or down, depending on the orientation of your mount, to lock it in place.
Dexter
Community Team
