xcskier
Jan 31, 2018Aspirant
AC1200 R6220 wallmount
This is one of the least technical questions on this board. I'd like to mount my 6220 router on the wall. The bottom face of the router has two -o- type holes, as if intended for two mounting screw...
DexterJB
Feb 12, 2018NETGEAR Moderator
Hi @xcskier,
There is actually a gap between the router's back and the plate which is enough for a flat screw head to slide in.
Dexter
Community Team
xcskier
Feb 12, 2018Aspirant
I'll be darned, you are correct. No gap at the center where the circular hole is, but there is a slight gap alongside the slots. Thanks.
