Dracman's avatar
Dracman
AC1200 R6220
Is there a list somewhere in the router of the different IP Addresses that have connected to the router? My old Dlink router had a log file with this information but I can not find anything like it o...
  • TheEther's avatar
    Feb 28, 2016
    You want the name that the printer considers its own. This rules out the share name; that's the name your computer uses to refer to the printer.
    Try HP2E2585. The printer likely reported it as its name to the router. Or try HP2E2585.local.
    If the printer has a display panel, then look through its settings. You may find a setting for its name.
