RodLee
Mar 23, 2019Aspirant
AC1200 R6220
How do I set up a guest connection on the AC1200 R6220? I just installed it and it automatically updated the newest firmware.
- Mar 23, 2019
> How do I set up a guest connection on the AC1200 R6220? [...]
Many people would follow the instructions in the R6220 User Manual.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Set Up a
Guest WiFi Network"?
antinode
Mar 23, 2019Guru
RodLee
I didn't find a manual in the box the router came in. I did find it on web and you were correct about the guest log in on page 122. I had to search that myself since you didn't tell me where to look on the manual. No being a techno nerd I do appreciate your response in helping me.
Thanks again!
- antinodeMar 23, 2019Guru
> I didn't find a manual in the box the router came in. [...]
Providing one would cost actual money. When was the last time you
bought any high-tech gizmo which came with a useful manual on paper?> [...] I had to search that myself since you didn't tell me where to
> look on the manual. [...]I don't know which program you used to read the (PDF) manual (Acrobat
Reader, some web-browser built-in, ...?), but it almost certainly has a
Search feature which would have done the job easily. A search for
"guest" would probably have been sufficient.> [...] No being a techno nerd [...]
You might save some time and effort by learning a few more of the
basics. ("What? I don't need to buy a separate ratchet handle for
every socket? Why didn't anyone tell me that?")
