Zimby
Nov 19, 2022Aspirant
AC1200 router dropping Internet repeatedly
I have a AC1200 Smart WiFi Router, R6220, purchased in 2017 with current firmware version: V1.1.0.50_1.0.1 (no new firmware version available). A couple weeks ago our Internet started going down ...
- Nov 21, 2022
How did you check that? That is by no means the latest version.
There have been a dozen or so since that one:
R6220 | WiFi Router | NETGEAR Support
This is the newest:
R6220 Firmware Version 1.1.0.114 | Answer | NETGEAR Support
I'd try that before going any further.
Zimby
Nov 27, 2022Aspirant
NETGEAR Genie was reporting no new firmware available when I had it search for updates. That is what misled me into thinking no firmware updates were available. I found the new firmware on the Netgear website and installed that - problem fixed.
My first impulse was to update the firmware. This was obviously a problem with the NEARGEAR Genie software in that it was unable to locate an update on its own.
The problem IS resolved. Thank you for your suggestions!
michaelkenward
Nov 27, 2022Guru - Experienced User
Yes. Netgear's update check is a joke.
That's why we recommend doing what you did. Check the support pages for your devices.
