sfvoyage
Oct 20, 2022Guide
AC1200 router only working for Kindle Fire and not laptop or phone
I lost wifi signal yesterday for both my laptop and (android) phone. However, my Kindle Fire has wifi signal and is working fine. Any idea what is happening? Do I need to buy a new router?
- Oct 28, 2022
The issue has been solved - it turned out to be with my ISP and not my router. (Happy not to have to buy another router yet.)
sfvoyage
Oct 21, 2022Guide
The model number of my router is R6220 (-100NAS).
I don't know what firmware version (sorry, I am not too technical - should I take a pic of the tech specifications from the box and attach it on here?).
I do not use a modem. My ISP is a local San Francisco company called Monkeybrains, and I connect directly their wall jack to my router using an ethernet cable.
I lost wifi a couple of days ago, and Monkeybrains has been resetting signals on their end and claimed to have fixed the problem. When I did a direct connection (bypassing the router), I do get wifi signal, although it's slower than usual.
What I don't understand is that, going through the router, I do get strong wifi signal on my Kindle Fire device. However, no wifi signal for my laptop or my android phone.
Does that mean that the router is working somehow but needs to be reset? Should I next try to reset my router to the original factory settings? If so, any tips for that? Many thanks.
michaelkenward
Oct 21, 2022Guru - Experienced User
That sort of setup is not typical. It may be that your ISP has some sort of router further up the chain, which means that you might have to put the R6220 into access point mode.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
