jtavana1
Jun 26, 2020Tutor
AC1200 Smart Wifi Router - Firmware Update
Hi, Hoping I can have my issues solved here! I've downloaded Nighthawk and was told my Firmware is out of date. I am unable to open routerlogin.net since I do not know the admin / password info (a...
- Jun 29, 2020
I rebooted the modem and it is fixed. Thanks everyone!
Jun 26, 2020Guru - Experienced User
jtavana1 wrote:Hi,
Hoping I can have my issues solved here! I've downloaded Nighthawk and was told my Firmware is out of date. I am unable to open routerlogin.net since I do not know the admin / password info (admin, password did not work). I don't recall ever changing it either. ----If you don't know your login, dont' know the password recovery questions, or if you didn't setup the password recovery options, then to get back in you'd need to factory reset it to get back to stock settings. The factory login info is:
login: admin
password: password
so you could factory reset (push and hold reset for 7-15 seconds while its powered on), update it, and then reinstall it.
Also, I am unable to register my product that I purchased years ago because I do not remember the date of purchase, and the serial number is 12 digits as opposed to 13 or 16 characters long. I can provide the info found on the bottom of my router if needed.---Not much point of registering. The main reason to register it is to get support. And if you're outside of the 90 day free support window (which you are if you bought it years ago) then it'll cost more for support than the router is worth.
Any help will be appreciated.
here's the manual, install guide, and firmware.
