jtavana1
Jun 26, 2020Tutor
AC1200 Smart Wifi Router - Firmware Update
Hi, Hoping I can have my issues solved here! I've downloaded Nighthawk and was told my Firmware is out of date. I am unable to open routerlogin.net since I do not know the admin / password info (a...
- Jun 29, 2020
I rebooted the modem and it is fixed. Thanks everyone!
jtavana1
Jun 28, 2020Tutor
The Nighthawk app did. Where else could I look? I've never had to do this in owning this device for more than 5 years.
My internet speed is 3.22 down and 35.32 Up. I'm not sure why it's been so slow lately, any my provider says there are no outages in the area.
Jun 29, 2020Guru - Experienced User
here's where you can find the current firmware version.
https://www.netgear.com/support/product/r6220
You can find what version you're on by logging into the router and checking on the status page.
what speeds do you pay for?
What modem are you connected to?
